Question for the experts. I'm rebuilding the front end on my 74 EB and decided to replace the seals on the front axle while I had it out. As far as I know, the axle had never been opened up before. Fluid looked normal for the age and I assumed it had been changed a few times over its life (no water or corrosion in the housing). I measured the backlash at 0.008" and the preload at around 4 inch pounds with the carrier out. It was really hard to accurately get an average of the rotational preload. From what I've read, the backlash is within tolerance (6-10), but the preload is below tolerance (6-9). This is my first endeavor into maintenance on Dana 44, so I want to make sure I do it correctly. The inch-pound torque wrench I have is new. It's a 1/4-inch Drive Beam Torque Wrench (ARES 70213). Is marking the nut\yoke and getting it back to that original position acceptable (assuming the preload is set back at 4-inch pounds)? Or should I push up in the 7-8 inch-pound range after replacing the pinion seal?
