NYLES
- Aug 13, 2004
- 9,846
Yeah, broken fingers in the sleeve.....
what I thought
How bout a "what I learned today" lesson...
Here's where I screwed up. First, I should have read enovey's post a little more. I thought the upper ball joint came out into the middle of the knuckle, wrong! So as I'm beating the crap out of the upper nothing is moving cuz I hadn't taken the nut off the lower. I put the press on it and mangled the threads meaning I couldn't get the castle nut back off. Well, I cut off the rubber boot and used a cutoff wheel to cut the shaft in half. Of course after I got the knuckle out I figured out that they press outward not inward %). I pressed them out and now I'm good.
So I press the new ones in the knuckle and go in reverse (of the proper way) and I'm good right?
Second one came off in about 10 seconds, life is hard when you're stupid
Phil, you are correct! I just read another thread that clarified it for me. Like the other guy I thought the inner portion of the sleeve was threaded around the ball joint so I assumed I had to take the sleeve out first to get the ball joint out. I'll give it another whirl!
If I had just looked at the new sleeve I would have seen it wasn't threaded
