    Discuss it more here:
Dana 44 Steering Knuckle needed
Status
Not open for further replies.
rutwad
I need a RH steering knuckle for a Dana 44. Part number is 35823 for the knuckle, or 27577x for the complete knuckle assembly. I only need the knuckle.
airman
I have a pair of them but they have been drilled to 3/4 to use a bolt and heims. from a 75.
mudstud
Bronco Bonehead
Excel
I have a set for a drum brake axle.. I am in South Alabama..
R
rutwad
It's for disc brakes. I think I have found one and it is being shipped to me. Hopefully it works.
72Sport
You might have better luck if you provide the number cast on the knuckle. The ones that I have seen are 6 digits followed by the letter R or L. The casting numbers that I have seen are on the arm that the tie rod is attached to.
R
rutwad
Mine is C35823. It is the RH passenger side knuckle. PM me if any matches are for sale. Poor Bronc has been the barn all summer. She needs to run around a bit before winter gets here.
R
rutwad
I mentioned 2 numbers, 35821 & 35823. I just found out that 35821 is the part number, and C35823 is the casting number stamped on the knuckle.
Status
