I also picked up my 35 spline axles (NIB) and used Warn hubs on Pirate- I think I was right around $350 shipped to my door. Not bad when you can find a deal. Definitely worth it to do this one right the first time.
As for the knuckles, I have the Artec high steer arms that I drilled to line up with the existing tie rod hole. This puts the steering bolt in double shear with my full hydro setup. This helps alot on the high steer knuckle failures. I am not sure how Kyle's was set up, but aftermarket knuckles are not cheap!!
Nice deal on the parts, I got a hookup off Pirate for mine, but paid slightly more. I did get Yukon shafts instead of the Nitro/10 Factory shafts they were having problems with. The pucks are easy to remove and seal back up - my diff is welded and I'm a trailer queen, so I don't need lockouts... I got both my knuckles to the door for less than ONE knuckle from anyone else, new or used. It was a score of a deal! The steel welded on mine is available in pre-bent kit form on Pirate, as long as you can weld and have a BBQ grill, you can do this at home.
It took me 3 years to break a stock outer stub...But maybe I was just lucky. I broke it with a set of Warn Lockouts. When it happened, it swelled my spindle and ruined the locking nuts removing them. Lucky I had spares spindles already or it would have cost a bunch more. The great thing with buying them before you break them, is you have spares to fall back on. So it does almost cost you twice when you break the stock stuff.
I need to look into the Artec or similar arms to double sheer mine....
I broke my first stub the first time out with my NP435 IN MY BACK YARD - the C4 was easier on parts. Every time I broke a $30 D60 stub it destroyed over $100 in parts. I'll repeat that. Every time I broke a $30 D60 stub it destroyed over $100 in parts. Do yourself a favor and plan on dropping $550 on stubs, pucks/lockouts, and SPICER ujoints.
I started off with Ballistic Fab hi-steer and PSC full hydro - I limited the ram internally and it still cracked nearly half way around the top of one knuckle. I wouldn't say I was hard on it, I drive into an obstacle easy and then pounded on it - still broke it. My link angles are perfect and it still popped -
I am on 37" Boggers and welded differentials. Everything I read said the D60 should be indestructible on 37's - NOT.
I would go with the Artec Fab hi-steer arms in a heartbeat - Ballistic makes a fixer for mine, so I'll weld these on for $30...
Destruction doesn't stop there - NP435 outputs, 35 spline D70HD axle shafts, D70 ring and pinions...
I'm starting to think I should pull the nice Spicer ujoints off the ends of my drive shafts and run parts store junk so its easier to fix... Well, off to build more horsepower and run bigger tires ;D
