Dang it I need to replace the floor pans in this rig Done Stamp look below
BowHunter148
At least u had floorboards to start with
Sent from my iPhone using Tapatalk 2
BowHunter148
Nice work brother. I am screwing my pans down.
I had cancer creeping up my tunnel cover and didn't want to wish I had replaced it later so my back is killing me after screwing 2 boxed of screws down then pulling each one out and welding
Holy mother I hope I never have to do that again!
Good Luck
shamu
shamu
Lucky as the day is long.
Sachse,Tx
Okay the next step is to tie in the hump and keep at it. I had to remove the heater box so I have anti freeze under the truck.
sprdv1
REBEL
at least you is taking care of the issues man... it'll be great when it's done
BowHunter148
Screw dat, Damon! Weld them in there to stay. Screws are for mockin it up. :eek:
I'm sure he's gonna weld her down, I think he's just getting them in place
Stingray240cs
Corinth, Texas
Re: Dang it I need to replace the floor pans in this rig
Can anyone explain the technique used to weld the holes after you remove a screw?
Sent from my Droid DNA
shamu
shamu
Sachse,Tx
Brandon; Bowhunter will stop buy and give me some great advice. He has done a killer job on his pans and I hope to learn. Bowhunter my cell is 972 754 9210. Call me I need help!!!!!!!
BowHunter148
I'll call u today!
I never thought anyone would ever want my help on this website!
Rox Crusher
When I did my floors I found it difficult to get a good weld between the new pan and the underlying piece. Since the screw hole is so small and is the same size for both pieces, it would close up before welding the two together.
On some, I was able to do it by angling the tip so that I was welding the edges together and then close the hole up after. This resulted in non-sexy welds which required clean up.
Where possible, I used a centering drill bit to drill through the top piece which made it easier to weld the two pieces together.
stupidboy
My wifes porn star.
Morrisdale Pa.
I usually use a 1/4" drill bit after I take a screw out and open up the hole on the upper piece of metal without going all the way through both pieces.
Chief Master Sergeant
Retired U.S. Air Force
I had the same problem with the first set of pans I did, so the next two I pre-drilled the pans and used screws sparingly. I also had my helper (Miss Stacey) do the spot welds while I held the metal down with a long screw driver.
Great work brother. Can't wait to see the final product.
shamu
shamu
Sachse,Tx
BowHunter148
The key is to have your wire touching the body metal, hit the trigger and do a circular motion to the center, I'd say it should take 5 seconds on the trigger
Another key is to put a screw down every inch so when u pull one screw you don't get separation, it's a lot of screws and welds but u don't want to have to scrape off your raptor liner because your floors are rattling.
shamu
shamu
Sachse,Tx
Thanks bro. I may also try the over head welding gig on the lower supports. I love burning up wrangler jeans when I weld. I save your # you are BOWHUNTER on my iphone.
