Dash Cluster Lights Dont Work
NEWB69BRONCO
Aurora
Well here goes my first post. I have a 69 Bronco Sport that is all original. Ive been working on getting it back on the road. Ive got all of the gauges working including the fuel gauge finally. However I cant seem to get my dash lights to work. Ive searched the forum and have tried to figure it out. I replaced the headlight switch and still no workie. Ive got power on all of the terminals on the headlight switch except for the blue wire with the red stripe. Also no power at the fuse block for the interior lamps. Any input would be much appreciated. Sorry for the long first post. Awesome forum with alot of great information.
fourdig
nucla colorado
hey, just a thought is to check your fuse panel i think the dash lights run through the fuse box and also the new light switch was it new or a used one
Viperwolf1
electron whisperer
Have you turned the headlight switch knob? That controls the rheostat which controls the dash light voltage. The current then goes through the 2 amp fuse #3.
NEWB69BRONCO
NEWB69BRONCO
Aurora
Thanks for the replies. Yes I tried turning the switch both ways and nothing. Headlights and taillights all work great. I have no power at the fuse block just for that 2amp fuse. On either side? Weird. I have power on all of the rest of the fuses. I pulled the fuse block and cleaned the terminals on the back. Were a little rusty. Viperwolf do you make housecalls? I live in Aurora also. LOL. Thanks for the help.
tasker
all knowing of nothing
NH
i live in NH but that sounds tempting....;D
Viperwolf1
electron whisperer
I've been known to make housecalls. I'll PM you my number.
The problem is pretty easy to troubleshoot though. Disconnect the plug from the switch and ohm between the brown wire terminal and the blue-red wire terminal on the switch. If its open ( even after turning the knob) it's a bad switch. Also make sure the running lights and brake lights are working.
