Dash Fasteners ?
robofig
Been working on body work and paint forever. I am now ready to install the dash and begin wiring.
Can someone tell me which fasteners go where to attach the dash to the tub.
I have figuered out the 2 brackets at the kick panels but need help with the rest.
Thanks for your time
old 71
There are two bolts on each side of the dash tward the top that go into a rectangle hole with u- nuts and I believe one #8 or 10 screw in the center top that goes through the face of the dash as well , plus the two bolts and brackets at the bottom as you mentioned .
Good luck
Dale
WorkerBee
Northern CA
You'll also have a series of screws across the top where the windshield folds down. Mine also had one right in the middle of the face of the dash and you should be able to see the corresponding bracket that one screws into above the defrost outlets of the heater box. I have a some pretty good pictures on my work computer so let me know if you need specifics.
