Dash switch ideas
bigjake
Denver
So after years of raising a family, I'm finally starting to commence with my '69 coyote swap. Currently, I've got the dash out for paint and I'll soon be working on installing the painless wire harness.
My body guy already swapped the speaker and glove box for cage clearance, but now I'm thinking about the whole dash as a clean slate. I.e. Don't think that speaker grate makes sense anymore.
Wondering what might be done useful ways to repurpose the following for more utilitarian uses (or delete):
- Throttle and choke cable holes, since those won't be needed.
- Emergency flasher switch, since that's now integrated into my new column.
- Ashtray, since I don't smoke.
- And I was thinking about running a replica blue tooth radio, but that's now on the table too.
Now that the body is restored I'm not likely to be doing any more hard crawling, just hunting and camping trips aside from driving around town, so won't need buckets of auxiliary switches.
Thanks in advance for your ideas!
sanndmann3
I started with a clean slate (blank dash) and laid it out the way I wanted...
post 5 in thread below...
fordguy
Filled everything and started over. Going to put a vinyl silhouette of my children/grandchildren in the blanket spot
.94 OR
Willamette Valley, OR
I have my CB mounted to the rear of my center console to keep it out of the way. I use the ext. speaker port and use the factory speaker location for the CB speaker. It is easier to hear if using the CB.
fordguy
I see the speaker grate is deleted. Is that your original dash or did you start over with an aftermarket blank?
Original dash! Thanks, minimalist is what we were shooting for.,went with Krawler’s sport cage so i did not need to move glove box door.
gnsteam
Lincoln NE
I had the body shop remove the speaker, ash tray and the botched old stereo opening. At that time and still today. I'm not sure what I am going to put in that new space
PDQ
Shifted glove box over, moved headlight and wiper switches to be next to each other, kept the heater cables in the same location and in line with the headlight/ wiper switches and eliminated the hazards, throttle, choke, speaker, etc.. The hole below the lights and wipers will be for a push button ignition.
eBronc2
Centered speedo, removed ashtray, speaker grille, radio hole, and all HVAC knobs. Relocated glove box. Added four 2022 Bronco A/C vents. Only knobs/switches are ignition, lights, wiper, and flashers, 2 on either side of column.
HVAC controls will be a tiny Vintage Air control unit mounted on center console.
SteveMa74
Did I just miss it, or has no one asked where this awesome center console is from? Would love to know…thx.
eBronc2
Center console is stock 6G Bronco (2021-current). The carbon-fiber looking top is just a cheap eBay overlay I got until I could find a real top for the console base. The console bottom edges required a little trimming to fit the early Bronco floorpan, but not as much as you'd think.
PDQ
More of a Maximist look. But of course my eyes aren't what they used to be so I needed big gauges.
LOVE the dual full sweep fuel gauges....so cool.....and so then naturally assuming you are running dual tanks, is the tank transfer switch the one next to the lower fuel gauge? And my zoom made the details blurry, so is your ignition the one below the vent next to the tach or where did you mourt that?
Definitely not the norm, but I love it.
