jms5580
Now that I've moved I have a little time on my hands so I'm trying to get her back up and running. Awhile back she started running rough out on a drive, sounded like a lot of metal thrashing around. By the time I pulled into the drive it was worse. After I shut it down it would crank but didn't start, and it sounded almost like things were grinding. I strongly believe this isn't engine related. A buddy of mine mentioned a cracked flexplate when I described the issue. I just pulled the inspection plate the other day and didn't see much other than a chipped tooth. I did a little researched and it looks like most cracks form in a ring towards the center. My questions (before I attempt to pull the trans in a storage unit) are can you see far enough to the center from this inspection plate to see this crack and does this sound like a legitimate reason for my issue based on the limited info I provided? %)
