No. Kits used by the dealers were typically what they could get the best deal on. Very universal, put on whatever vehicle needed A/C on the sales lot. Bronco, F150, Pinto, Maverick, whatever. Handful of engine bracket kits. Hose off a bulk roll cut to fit. If any instructions existed, they are very universal. Use on 12V vehicles only, be sure to have an adaquate engine cooling system, use correct compressor mounting bracket for the engine. You put holes to run hoses in the places you find they need to go. No drill 1-3/16" hole 2-7/16 from the edge. You have the parts, where does the hose need to go through, punch that hole, run the hose, and if you are good have some putty to seal up around the hole when done.
