Deep C4 pans
rylsky
Southern CA/NV
I see there are many deep pans for the C4: B&M, Hughes, Trick Flow and even FoMoCo. I want extra capacity but does a 2 quart hang too low? I also need to mount a temp sender so what do I do? I know I can get a pan with provisions for a bung but with aluminum do I just drill and tap?
I also see pan fill or case fill. What did the bronco come with and is there an easy way to peek under and make sure what I have? Are there pix someplace on-line I can refer to?
Lastly, is there an advantage to a cable kick down from the one-piece road style?
Thanks,
G
74bronc
I also see pan fill or case fill. What did the bronco come with and is there an ewasy way to peek under and make sure what I have? Are there pix someplace on-line I can refer to?
Thanks,
G
I can't comment on which pan to get because I don't have one yet, but the Broncos definitely came with the pan fill C-4 (if your C-4 is stock EB). You can make sure you have a pan fill by crawling underneath and checking if the fill tube is screwed into the passenger side of the pan. If there is nothing going into the side of your pan, you have a case fill C-4. The best way to do a temp sender is to get an aluminum bung (1/8NPT) and have it welded into the inside of the pan. You might get away with drilling and tapping the aluminum of the pan, but it would depend on how thick it is cast.
The manual lever type kick downs work great but the cables are a little more whiz-bang. You can make them fit a wide variety of carbs fairly easily
73stallion
Eugene, OR
we used the hughes pan from driven auto parts on jones'. it doesn't hang down any farther than the crossmember mount, so it's well above the lowest point of the transfer case.
we drilled a hole in the side of the pan below the dipstick fitting for the temp sensor, but i've been told by many that you don't want the probe in the pan.
what are you running for exhaust? that's the only thing you're going to have to worry about. if you have full length headers, you may have to run a lokar tranny dipstick, because the fitting that the dip[stick tube makes it stick to the side farther. you may have even more trouble if you run headman shortys.
BTW, i have a brand new autometer 2 5/8" oil temp guage for sale. it can also be used for a tranny temp guage.
bigmuddy
Marthasville Missouri
Deep C-4 pans
I have a TCI pan fill style it's a nice thick casting but I also have long tube headers and the stock tube would no longer fit because of the thicker brass adaptor TCI uses for the pans. I then bought a Lokar flexible dipstick and low and behold it is flexible till it gets down to the pan and it looks more or less like the stock dipstick tube! So it wouldn't fit either :'( I took the Lokar dipstick to a fab shop and had it cut down and tig welded so it would fit. I think we took out about an 1"? not sure on that though. I could have cut down the stock one and mig welded it but it was leaking and cracked so I decided to buy a new blinging dipstick.
