Deleted
nickm
South Houston
Hey all,
I just got another pony.
Here is the way she is right now
302, 3-speed, 9" Ford rear-end, Dana 20 Transfer Case, Dana 44 Front Axle
Additional Features:
* Hard top and soft top
* 33 x 12.5 x 15 BFG Mud Terrains on all 4 (+ spare)
* 15 x 10 Mickey Thompson wheels on all 4 (+ spare)
* 4.11 gears
* 31 spline axles, front and rear
* Detroit lockers, front and rear
* James Duff lift kit, 3.5"
* James Duff dual shock kit and 8 shocks
* James Duff steering stabilizer
* 11 leaf Wild Horse rear springs
* Fresh motor
* New Edelbrock aluminum intake
* New Edelbrock carburetor
* Ford SVO aluminum rocker covers
* Ford SVO aluminum air cleaner w/K&N filter
* G.T. Grant steering wheel
* James Duff 3-speed floor shift kit
* Full family roll cage
* New interior upholstery and door panels
* New interior carpet
* New interior rear quarter panels
* New door seals
* Power steering from F-150
* New power steering pump
* Power brakes
* New front brakes
* New CD player
* New heater coil, blower and housing, hoses, gaskets and heater valve
* New light switch
* True dual exhaust w/Flowmaster mufflers
* New front light gaskets
* 3-point safety belts
* New fuel pump
* Optima battery (red top)
There was a few things I wanted to do. I planned on collecting parts and doing a little at a time. Well I lucked out, I thought. I thought all the 5.8 were the same. I read today that there was a little difference.
I hope to:
change the upper to a 5.0 with a MAF
add inside lights from the truck
swap the front disks
install my 9" disk set up (Chevy/Dodge parts)
add the seat belts from the truck
pull the under hood light from the truck
The disk swaps are pretty easy,Ive done those before.
Light are also pretty easy, I plan on adding fuses and relays
What I need to help, hint, tips, trick on is the engine swap. Ive read a lot about the swaps. I have a 5.0 and C6 with a 203/205 in my Bronco buggy. I didn't bother to spend any time to learn about the 5.8, I never though I would fine one. OH BTW I paid $600 for the whole F150. I would like to use the auto from the truck. But it looks reallllllllllly loooooooong. I would also like to use the 1356, But I haven't spent any time to see if they will fit in the Bronco. I am look to make this a tough daily driver not bullet proof crawler. I am building one of those.
I have limited funds. I am down to less than $1000 after buying the F150.
Whadda ya think?
fatboy
Glad to be here.
New Hampshire
Sorry I am a little confused from your post. The listed parts up top, are they already in the red truck shown and you just bought that? Sorry the link is down now on the CL post link, so was that an addition parts truck to take the motor out of? If i just bought the red one, I would drive it like a stole it, pull all the parts off the donor you want and get rid of the rest. Then I would do the easy stuff you are talking about first. The tranny, motor, and tcase swap sounds more like a wheelin set up and I would look more towards a streetable tranny like one of the 5 speed conversions like a 3550, 4500, etc.
Anything can be done if you are willing to pay or capable of doing the fab work.
Hope I am making sense.
nickm
nickm
South Houston
The list up top is whats on the Bronco now.
Here is the parts truck I bought
1992 Ford F150 4x4, long wheel base, single cab. Has quite a bit of body rust as it came from Minnesota. Runs and drives and the 4x4 works. The interior is great. It has 166k miles, AC, locking hubs, 351 engine and automatic transmission. There are no tags, license plates or inspection but I have a clear Texas title. You can transfer the title but they will not give you tags until it is inspected. One of the fuel pumps is not working and the other gas tank has a leak at about 1/2 full. It probably needs new exhaust as well. I have replaced most of the brake lines and some of the other brake parts. I was going to use it as a 4x4 toy but I don't have the time and the wife wants it gone. $750.00 OBO. Email for an appointment or if you have a question.
mustangtoby
southwest Colorado
The Bronco looks like it is about perfect right now. I assume you want the 351 for more power? The 5.8 swap is pretty straightforward, bolt in. Search will tell all you need. I think you will need a body lift or cowl hood to clear the 5.8 intake, but it will all bolt up.
br0nc0xrapt0r
Loves pickles
yeah I think it is a big deal to make a 5.8 efi fit in an eb with the height of the upper intake manifold
nickm
nickm
South Houston
I plan os swapping the upper for a stang 5.0 upper and getting the adapter from BC.
I think, correct me if I am wrong, I need the upper intake, MAF sensor, computer, adapter. Right?
About the wiring harness, I planned on doing the SD harness with the MAF conversion wiring. I got my last conversion wiring harness for about $90. Unless I can get the MAF harness with the upper.
br0nc0xrapt0r
Loves pickles
this may sound odd but why don't you take the 5.0 out of your buggy for the bronco and put the 5.8 in the buggy?
nickm
nickm
South Houston
;D ;D ;D
I don't want to start robbing parts off the buggy. I may if I can find a C4 though. I have the E4OD/BW1356 on Houston craigslist for $700. I saw a E4OD listed for $600.
If I can sell it I can buy a C6/?. I am not sure whats attached to the C6. Its at the bone yard right now. It most likely a 208. And as luck would have it, I don't know squat about the 208s. I am tryin to stay away from the 205 due to the width. On my buggy I only have about 1/2" of room between the 205 and frame. On the buggy it doesn't really matter, I can route the exhaust outside the frame. But the Bronco, I am not sure how it would fit. I have a Borla exhaust waiting to go on it.
I have been reading for about 6 hours tryin to get this stuff straight in my head so it doesn't cost me any more $$ for mistakes.
nickm
nickm
South Houston
Well I picked up my A9L last night, $75. For the MAF swap all I need now is the wiring pigtail. I can order that any time for about $80. I am going to get everything and swap it into my parts truck and make sure everything is running good together.
Now I really need the think about the transmission and transfer case. Right now I am running 33s (35 maybe later) 4.11:1 with a 3 speed. I was going down the hwy last night doing 65-70 and my RPMs were 4500-5000. So I want to get them down.
  1. I can keep my 3 speed and D20 (high RPMs)
  2. I can get a C6 and 205 for about $250 (high RPMs)
  3. I can get a C4 and D20 for $250(high RPMs)
  4. I can get a 4R70W for $350 with a computer ?? transfer case
  5. I have an E4OD and BW 1356 (can you say LLOONNGG)
  6. I can get a AOD and ?? transfer case
nickm
nickm
South Houston
I am still tightening stuff that was on it when I got it.
Pedestrian
Bronco Missionary
Go to the 35"s that will raise your gearing and make you much happier on the freeway.
