Explorer 5.0 swap...the dreaded PATS got me 😣 PATS deleted eBay PCM an option?
skrit
Bull City Bronco
Durham
My question first, related info after:
I'm going to have to delete PATS like everyone else did instead of chasing all this down. I know @EFI Guy is retired so my question is: Can I just buy a PATS turned off PCM from eBay for $200 that matches my original PCM model number, slap it in and be done with it?
Related info:
I reworked the 1998.5 explorer harness and kept as much of the electronics as I could for engine run test while the body is still off the chassis. I am using the original steering column, PATS module, ignition switch key and lock cylinder (column is on a cart and connected into the wiring harness).
I have one original key marked "S" and the PATS transceiver and kept it all wired up. PCM is original. Connected a new battery, crossed my fingers, turned the ignition and bam...the fast flashing "theft" light on the dash. Waited and got the 1 blink / 6 blink pattern. I can hear a relay clicking in the battery junction box (it's the PCM power relay) but everything is immobilized. I tried connecting a Bluetooth scan module to the ODB2 port and I think that is also locked out.
Transmission range switch is in Park (all the way back).
I bypassed the inertia fuel switch (I did not install a new one) with a wire jumper in the connecter between the 2 pins - no luck nor can I hear the fuel pump running.
Not sure what to do with the brake pedal position switch - could that be an issue? It's not an issue.
EFI Guy
TheEFIguy@gmail
BFE
I retired from swinging wrenches on German cars. I'm still doing the EFI Guy thing. My email is to the left, or call 720-58TUNEZ.
skrit
skrit
Bull City Bronco
Durham
Will do sir. Thanks for your reply. My nephew happens to be a Ford mechanic and has a Forscan tool. I'm going to try and disable the PATS. Can't think of any reason the starter relay and odb port is inactive. Odb has power just no comms.
I've actually enjoyed tracing out wires and reading wiring diagrams. Would like to start from scratch wire by wire but can't find a source of all the striped Ford colored wires.
