Design my trail rig
JohnJohn
Richmond
I have a bronco frame, beat up tub with a cage and a welder. I am looking for sugestions as to what other parts i should toss at this project.
I am thinking about buying a junk yard truck and using the engine trans transfercase driveshafts and diffs.
Thinking of dana 60's full width.
Any good doner sugestions or should i just peice it together?
ep67bro
Bronco Junky
Easton, MD
A late 70s Ford F250 or F350 would be a good truck to get the drive line from. But finding one with dana 60s front and rear and cheap enough to justify parting the truck out could be a challange. I would stick with bronco drive train and parts it will be cheaper and easier than full size stuff. You can run 38" tires on bronco axles with a little upgrading.
KyleQ
If you want to beat on it and have fun, go full width 1 tons. You can have fun with a hot 351, even a big block with that drivetrain from a F350 and not have to upgrade anything. Easiest way is to get a complete truck and carefully grab what you want, I pieced mine together over a long time, but it was simple enough, I searched for the best deals one by one, could have saved money if I got an entire truck.
