Dfw msd box help
blue bronc
Fort worth
Does anyone here in the DFW metroplex have an extra MSD 6AL box?
I have the 6AL off-road box and am having some issues with my Bronco not starting. I have had issues before with the same model different box. I had the coil and box tested locally and they told me that they are fine.
But I am still having issues it will start and then shut off.
Per MSD instructions you can jump the magnetic pickup and if it is working you will get a spark I got no spark. Would a broken mag. pickup prevent me from getting a spark? Someone told me the mag pickup may be broken and to replace the entire distributor.
I have checked the connections and all looks good. Would a
The last time I just plugged the new box in and it fired right up. That was three years ago but I have only put 12K-14K miles on the current box.
So what I am thinking is if I can test the system with another box I can rule out the other parts.
Any input is appreciated
bax
Old Member
By pass it. it will run with just the coil.
Although a new distributor is always fun, you can just buy the few (and relatively inexpensive) parts to replace the guts.
Better yet though, there is an easy test you can perform with an ohm-meter at the connector. Don't have the values memorized, but it's here somewhere, and probably in the MSD instructions as well.
