differential gear selection
jamesonfd
I've got an opportunity to select gear ratios for my 70...that is, my "new" 44 in front and the 9" don't match. The rear is 4.10, and the front 3.50. I have a NV3550 and 35" tires. Goal is roadable with some off road capability...not a "serious" rock crawler. Looking for thoughts on which I might choose to change; cost is relatively the same (or within $100 or so).
Thoughts? And thanks in advance.
Quick & Dirty
4.56 is the go-to for 35", but with overdrive you could go lower. Where does the engine like to run? Can you lug it along at 2000, or does it need more rpm? How fast do you want to go on the highway? 65... 80mph?
I was leaning toward 5.14 with 5.0 and automatic overdrive (.7) to keep the rpm up. 2150 at 60 mph, 2700 at 75. With the .78 od gear in the 3550, 4.56 would be about the same rpm. 4.88 would work if you're not doing much interstate speed.
blubuckaroo
Grease Monkey
Ridgefield WA
This sounds like the car is new for you.
Are you planning to keep the 35" tires? If so, 4.56 gears sound right. H
However, if you decide to use 33" tires, 4.11s are better with a NV3550 tranny.
rjrobin2002
4.10 if your being cheap and only want to switch one axle.
4.56 if you want to use your 5th gear.
I had 4.56 gears, 35" tires, and NV 3550 and could only use overdrive around 70mph or higher.
I wished I went 4.88 so I would be switching to overdrive around 60 instead.
J
jamesonfd
The truck's not new, but driving it is. Just finishing long (8 year) build (thanks, COVID!). 35s will stay. Thanks to all for the input.
blubuckaroo
Grease Monkey
Ridgefield WA
I was just throwing that in for an option for other members who plan on an NV3550 tranny but don't want to go to the other items needed to run 35" tires.
Apogee
Tangent, OR
If 302/5.0, I'd probably run 4.88 gears because of the OD. If 351W/5.8, I'd probably go with the 4.56 option due to the higher torque at lower RPM's, though we're only talking about a 7% difference between them, but you asked for opinions. Either option should still let you go faster than any sane person might want to go in an EB at redline in 5th gear.
CowboyGrin
the circus looks like fun
Oklahoma
I've been studying the same topic, but looking for a balance between crawl ratio and highway cruising (as if there was such a thing). Showing my nerdiness, but I whipped up a spreadsheet some time ago to look at different scenarios. I put your values in to see the results and compare to the real-world experiences discussed. Hope it helps.
FYI, ignore the Underdrive/L references. The input assumed a D20 without a doubler, so the spreadsheet just ignores it.
Since you want to do some off-roading, look closely at the drive/crawl ratio at Gear 1-L. Most generally want this 50-60 for light trail use and in the 80's for intermediate trails.
  • Gear Calcs.pdf
J
jamesonfd
Many thanks, very helpful!
blubuckaroo
Grease Monkey
Ridgefield WA
Another thing to consider is the first and second gear ratios of your NV3550. It's lower than most overdrive tranny's and a lot lower than a three speed.
I've got 33's and 4.11s. A lower axle gear ratio would make the first gear practically useless.
