Dipstick install
Ken.thompson1@a
My 68 Bronco has a 289 original engine with a failed previous braze repair. Leaks. I have purchased a Ford Performance M-6675-A50 pan kit but now realize the original dipstick tube enters through the pan while the kit dipstick enters through the block. Apparently 83-95 302/5L have that provision while earlier blocks did not. Any suggestions or experiences on how to work around this problem? Other info- rear sump. My289 was built on a 302 block per casting number. Appreciate any and all input
4xfun
Mine also leaks and I just have not gotten around to fixing it, but several others have. Check out
Several options are discussed.
ba123
CA
So, to make sure we understand...you are saying that you have an original block and originally, the dipstick is through the pan but this kit, since it's for the 5.0, is set up for the dipstick through the block (and you have no hole there), correct?
If I'm understanding correctly, your choices would be to either send the kit back and get the correct one for your application or weld in a dipstick in that pan. You could also do the front cover swap to one with the dipstick provision assuming that would work with that pan in terms of reaching the sump).
If not understanding correctly, please clarify.
Ken.thompson1@a
Ken.thompson1@a
ba123 you are understanding correctly. Tom's off-road is the only source that advertises a pan kit claiming an application for 289/302 Broncos 66-77. The picture looks exactly like the Ford Performance kit I purchased from Amazon. Price is salty plus their being in Oregon and me in Indiana shipping will be just as salty. I suppose I need to call them to verify it's a stick through the pan design. I appreciate your input.
Shimmy
1977 Bronco
Maple Valley
i'd definilty just try and find the correct pan. it wouldn't be worth my time to weld a provision on it when there's kits off the shelf. just my opinion. keep us posted.
Most of the Bronco vendors should have a proper kit (ours is #8066) with the dipstick hole in the pan. Probably Summit does too.
Maybe even Amazon if you search deep enough, but apparently you simply got the wrong kit based on incorrect information from the seller.
Which is an Amazon hallmark these days.
Many people, even those who know to keep an eye out for it, run a foul of incorrect parts coming from Amazon.
If it hasn’t been too long, perhaps you can return your Amazon parts without trouble.
Good luck.
SeaVee
I’m also working with a late 80’s 302 in my 77. The dipstick hole into the block is right under my new Brake booster, between my header pipes and I cannot orient it so I can use it there, can I put the dipstick in the front of the motor?
ba123
CA
You can if you have a hole there or switch to a front cover that has it AND use a pan that will work for measurement there.
You could just bend the dipstick tube or find one that is more bendable.
I was gonna suggest the same thing.
At least initially, to avoid going through the hassles that the other options put forth, a different dipstick with a longer tube that you can bend around the brake system might be a viable option.
SeaVee
I have the Locar push in now. Tried two different header bolts and I still can’t get enough access. The Tom’s brake booster bracket seems to block it.
I do need to get an oil pan for this motor, what would you guys suggest?
Ken.thompson1@a
Ken.thompson1@a
Ken.thompson1@a
Ken.thompson1@a
Good luck.
Really appreciate the input. I will check it out on the website.
Good luck.
Great info. Actually I have to own purchasing wrong item their description did say for an 83-95 Mustang with a 302. It took 3 attempts to get a 302 rear dump pan with other items listed as a kit. First two were Reship of previous returns. Once in my hands I could see no provision for dipstick into pan.
Ken.thompson1@a
Ken.thompson1@a
So I have ordered a proper kit from Wild Horses 4x4 and have an RA on the Ford Performance Kit to Amazon. I have direction! thanks.
Ken.thompson1@a
Ken.thompson1@a
Have done so....correct kit coming from Wild Horses 4x4. Thanks for the input
