VoltageDrop
Newbie
- May 3, 2018
- 12
Disc brake swap parts for D30 or D44. $325 ($275 without the calipers since I can use them on my Sterling and shipping might be reasonable minus those) $25 off either price if you pick up!
2 new Raybestos hub/rotor assemblies
2 GM spindles (used)
2 GM caliper brackets (used)
Longer spindle bolt set w/washers
2 GM reman calipers
2 new caliper hoses
Dana 30 drum front - clean with fresh paint and new Timken king pin / wheel bearing parts 4.10 open. No steering.
Matching 9" rear - small bearing / 4.10 open (assuming) and gunky 50 year-old appearance
74 9" big bearing housing with brakes and 28-spline axles and a bare 3rd member. Housing was stripped and perches cut off by previous owner.
Dana 44 drum hubs and backing plates w/shoes and hardware
Dana 44 (LP) 4.10 gears (minor chips, can send pics)
Dana 44 (LP) 3.55 gears / open carrier
Ford 9" 5.38 Richmond gears - used with chips on pinion outside mesh area
Ford 9" pinion guard $30
302 / 3-speed / Dana 20. Engine block is an 80's casting. I have a new 2100 carburetor and fuel pump for it.
05 SuperDuty Dana 60. No lockouts, steering, or brakes. $400
2 GM reman calipers
2 new caliper hoses
