Disk Brake Kits
joebronco73
Lago Vista, TX
So, my bronco has been in the repair shop for some major front end repairs after my ex drove it into the back of a work truck :eek:
After a month of having it, the repair shop called and asked about the brakes not responding at all, then offered to have their brake shop check them out. I agreed, but explained the brakes were working perfectly before (no lie, I was driving the bronco daily before hand). Unfortunately, the brake shop says all 4 corners need replacing, but it will cost me $750+ to fix/save the factory drum setup. Luckily, I was already planning a front disk conversion. So I think I will have them save the rear, then convert the front on my own, since I have access to all the equipment at my work. Before I decide, I need some help answering questions...
My questions are:
1) I have been considering the kits from TBP and WH, but what is the difference? Also, is the ebay kit any good or comparable?
2) Who has either and which was a better setup/install?
3) What are the best points for putting the bronco on a two-post lift?
I'm sure there are a lot of threads on the conversion itself and some of the kits, but I haven't got a lot of time to research it anymore and these are the questions I still ask after doing the research I have done. Its a '73 and has a 44 with Warn premium hubs, stock suspension and body mounts, factory PS, no aftermarket steering linkage, and no brake booster. I intend to add a power booster down the road, but keep the rear drums. Thank you all, in advance!
doghows72
I have been heavily researching this as well. My conclusion is the TBP kit. If you take the horsepower sales kit and add all the options to make it equal to Toms, the Toms kit is better and less expensive.
Now I did the same with the TBP kit and the WH kit and these were a lot closer but the Toms kit came in less expensive when you make sure both kits have the same parts. It really almost comes down to shipping between the last two.
All three kits appear to me to be using the same pieces to make the kit so just make sure you compare apples to apples!
BOBS 2 68S
Hudson, CO
I have the kit from Toms on both of my 68's. No problems here. The 1/2 cab has been on for about 13 years. And I have both front ends a 30 and a 44
jmangi62
I used the horsepower sales (e-bay) master/booster combo,and I bought the rest on sale from Duffs.Everything works great and went together well,plus I saved a bundle buying stuff that was from a Xmas sale,I hate buying stuff then a month later its on sale for less,that sucks lol.:cool:
Justafordguy
You should do the rear drum brakes yourself also. They are super easy and the parts are cheap.
hyghlndr
Hockessin, Delaware
The Duffs kit is a little more money but they actually have the knuckles cast so you can use all stock 1977 Bronco brake parts. The caliper brackets are also cast metal and not bent sheet metal.
BigEasy73
Atlanta, GA
I used Tom's Front Power Disc Conversion on my last rig and was very happy with it. Stopped on a dime and did not pull at all. I had it installed at a local shop.
904Bronco
San Martin, CA
I have used Tom's, WH's and Horsepower sales on EBay. They all worked.
Ebay, I bought a kit that someone else had for sale on Classic at a discount.
There were a few pieces missing and Dan at Horsepower was helpful in getting the parts to me.
Tom's, I bought theirs on a Christmas sale for a good price, even with shipping. The booster had an issue a year+ into use, they replaced it for the shipping price.
WH, Again end of the year sale and no shipping since Dirtdonk > Paul brought it home with him.
All three worked as described, comes down to price and shipping. If you can turn a wrench well, a lot of the smaller pieces (seals and such) can be sourced locally, saving a few dollars. Or you can buy the complete kit.
The grinding on the Drum Knuckles for clearance of the Caliper can be a little intimidating, but needs to be done.
joebronco73
joebronco73
Lago Vista, TX
Thanks for all the info, guys! It is helping a lot. I'm strongly leaning towards the WH kit, as I'm in southern california, so I could save a little on shipping.
Fordguy, I may yet do the drums myself. Only reason I consider having the shop do it was for the sake of time. I was planning on replacing the actual drums on my own, along with some of the misc parts, but I suppose it would take the same amount of time and save some cash if I did it.
sprdv1
REBEL
That shipping can eat you up sometimes. good luck
DonaldDouchebag
I'd just buy a set of used Chevy spindles and backing plates and buy the rotors/hubs, bearings/seals, calipers, and hoses at Napa. You can save hundreds doing it this way.
These are heavy boxes, so yeah, shipping is an unfortunate byproduct.
And sorry I'm not close enough to give you the same "shipping deal" Doug got Joe!;D
If you do end up going with the WH kit Joe (thanks by the way!) definitely call to see if there is one method better than another for shipping. To SoCal I kind of doubt it, as UPS and the one or two others we typically use for west coast shipping are pretty close in cost. And for stuff this heavy, the Post Office isn't a viable option.
If you prefer to order online, simply request a shipping quote in the "NOTES" section and one of the guys will call with options.
Anything is going to pretty much be the next-day delivery, so cost is the main curiosity at that point.
Good luck.
joebronco73
joebronco73
Lago Vista, TX
DonaldDoucheBag (that name! haha) - that was said by a coworker, who is an avid chevy guy. The only draw back I see is that I would have to lathe the rotors and put in extra time to clean up the used parts from a pick-a-part yard, which I am trying to avoid.
Paul - that's what I figured. Trust me, I wish I was closer, but San Diego is a hard place to leave :cool: I may be able to work something out with my work and have the boxes shipped to corporate, then they could truck it down for me (it would be shipped to our R&D facility anyway).
Best solution I can think of off the top of my head... Road trip!!!
Stop up this Saturday for our annual Bronco Roundup, check out the possibly 200+ EB's (weather is going to be perfect!) and go home with your new parts in-hand.
For sure it would be fun. Long trip, but could be a blast to check out all the stuff. And talk to a few hundred people that have done the same thing you're doing.
Win win, as they say...%)
joebronco73
joebronco73
Lago Vista, TX
Paul - that has run through my mind countless times, since getting the quote from the brake shop yesterday! Sadly, I can't make the trip, even though I had wanted to go to Roundup since the beginning of the year :cry:
I do hope to head up and go to some events in the next year because I need some more Bronco Buddies haha
DonaldDouchebag
I just bought a set of hubs and rotors to fit a '78-'79 Bronco from Napa. No lathing and no core charge required.
DonaldDouchebag
I don't know what I was thinking with this name. It's super awkward when I meet Bronco guys in real life. :cry:
doghows72
I looked into the buy the used Chevy stuff, and you actually spend more money on that type setup. First you have used parts, second is the clean up time not to mention trying to find the right parts, then you go to Napa and spend $300 on fittings and bearings and hoses but you still don't get the stainless brake lines.
You are on the right track, where you are go with the WH kit. It really comes down to shipping.
DonaldDouchebag
Nah. It's still much cheaper. The only part you really need to clean is the backing plates and that's no big deal. Time is the limiting factor, really.
doghows72
My issue is finding the used parts. Out here my closest salvage yard is 45 miles away and they don't have sh*t.
If I could source the used parts for $100 I figure I could be all in at $500-$600 done. The one thing not mentioned or included in most kits is the prop valve, so don't forget that! Unless your going disc disc.
