That's about right for a Bronco. They were a tight fit when new.
Can't use an original fan, that is a reverse rotation waterpump. You need a reverse rotation fan to move air the correct way.
The latest and greatest fix is to use the complete front on a 5.0 Explorer engine, very compact and gives room for a nice clutched fan.
My last mix of cooling parts required a 5/8" machined down fan spacer. 3/4" was langer then I liked and 1/2" hit the crank pulley. Needless to say, they are a tight fit. Not any fan will fit either.
As for electric, they have issues as well. The aftermarket 2500 CFM fans just can't pull anywhere near that airflow when you make them pull air through a radiator. People have had good luck with Taraus fans (search) but they have another drawback, massive power consumption. You need a better alternator to keep up, and the stock wiring can't handle a better alternator. Makes life interesting...
And you wonder why there are always issues with people keeping Broncos cool...
