Distributor Experts Needed
recoiljunky
Dothan, AL. USA
I'm trying to figure our if I have a provlem with my Duraspark dizzy or cam. With the dizzy installed in my 351W blocked engine, there is a little slop in the dizzy shaft. Not the movement from the mechanical advance, but slop in the shaft.
I removed all the parts related to the mechanical advance in order to recurve the dizzy (again.) While at it, I noticed that the shaft had slop in it. The slop is rotational only. The shaft ***clicks*** about 1/16 of an inch.
I'm letting the camcorder charge and I'll take a video in a little while.
What do y'all think? Normal gear meshing? The cam is new, the gear on the dizzy is cast like the cam gear, the motor was broken in properly.
bax
Old Member
Normal gear mesh slop is what I am thinking..
broncnaz
I agree probably normal gear meshing. Worst case just pull the dizzy and inspect the gear for wear.
