jakeperry
I think I m be180 degrees off.
What I did
Installing procomp66969b distributor. 302 stock.
Ok I turned the motor over w the #1 plug removed. I felt pressure and was at ten degrees. Of tdc. The marking was 10 -0 - 10. I was on the ten to the right of the 0 looking from straight down. ( I read this was right.)
Removed distributor and the skinny part of the rotor was pointing at 6-7 cylinder (I marked the top of the motor)
I reinstalled new distributor with the skinny part of the rotor pointing as close to the mark as possible.
Installed new plugs and new wires ( wires for this distributor come out of a 75 v8 camero fyi). I gauged new plugs at .35.
She will turn over but that's it. I got one back fire. And it just doesn't sound right.
What I did
