anyone got any tricks on getting the distributor to align on the oil pump shaft. i tried for two hours to get it in there. i tried turning the engine and turning the shaft.
Some times you just get lucky...But juse make sure you have the right dist for the cam..and while you are sliding the dist into place the shaft will turn as it ingages the cam teeth...after that its a matter of just jiggleing until it slides into place. My auto tech teach would pack the area around the oil rod with grease to hold it in the center and then its just a matter of sliding it in...if you were closer I would just run over and give it a try.
If it's splined up with the cam shaft gear but not going onto the oil pump shaft I always turn the motor while holding down on the distributor and goes right in. You'll have to get your timing back to TDC afterwards.
I use a deep 1/4" drive socket to turn the pump drive a little at a time. The drive will lay over to one side sometimes so I put a small O ring over it and in the bore to center the drive, you can leave the O ring. You can get it into place with a long screwdriver.
I get the gears to mesh as far as they will go so that all that is holding it up is the hex of the oil pump driveshaft. Then, I bump the engine over with the starter and it falls right in.......every time. Then, just put the motor back at TDC and you are good to go. I also put a dap of grease on the end of the dizzy to make it slippery for the oil pump shaft.
If all the above doesn't work, compare it to the old distributor. It may be possible that someone dropped in a 351 and didn't tell you about it. In that case, the replacement 302 distributor will never fit. The oil pump driveshaft grew from 1/4 to 5/16 when the engine grew up.
it was the same distributor so i knew it fit. i tried all of the above listed tricks and in the process i guess i damaged the tip of the dizzy. some of the metal had burred over and was blocking the shaft from going in, so i spent fifteen bucks on a set of files at lowes. i filed it down and it slid right in.
