Silverhorse
That makes sense. Thank you.
No problem, Thats why I'm here!;D
Those are the ones I was talking about. They have a stamped ring so no coning and they come with hardware. I know lots of guys running their setup and they thrash on their rigs. If you are interested I can get you a number to call and you will save big $$$ over the website price.
Hey Doc,
Did you get your rings painted to match your doors?![]()
;D
That Price Is Per Wheel With Hardware.
Mine. All the bolts/nuts are flanges serred heads I had a friend make for me.
Have you seen these? Not sure if its what your looking for, but works with almost any wheel, and is a inner and outer bead lock. Great design. Think it might be better than actual bead locks... Just a thought.
http://www.staunproducts.com/beadlock.php
There just happens to be a DIY beadlock article in the current issue of CRAWL. Pretty good except for the fact the bonehead uses steel BB's for balancing.
Anything interesting, I don't subscribe, yet.
What grade bolts are you guys using on the beadlocks? 5 or 8
Socket head? Is that the same as hex? I'll look on their site .ThanksI am running poison spyder bead locks, 17x9.5. I just copied and pasted this from their site.
Grade 8 Nickel Plated 3/8" socket head hardware is standard on all Spyder Locks.
