DIY of the BCB arctic air box?
bronco italiano
Doesn't look like BC makes the arctic air box, has anyone done a DIY version. I like the use of the passenger hood air inlet. Trying to not use the battery tray area for air intake.
JKH67302
I have the BC box and it's a cool idea, but it could be improved on. It's a bit too small for filters. A DIY solution could address this. If you not cramped for room on the fender you could use a bit more fender and move the filter to sit at a 45° in the box and it would be a much better fit and the intake hose would be easier to make. The box could also be a bit taller to facilitate more filter options. After some searching I did eventually find an AEM dry filter to fit the existing box.
Sent from my SM-S916U using Tapatalk
