I am going to try to paint my bronco myself. I am going to start with my 76 Highboy to work the bugs out if worse comes to worse with that I ll just line-x it if looks bad. Then Ill know if I can move on too my bronco. My question is if I put multiple coats of my base color in light coats avoiding runs but enough layers to avoid orange peel I should be able to block sand it until I get everything smooth. Will this work? I know it will be a lot of work, but I think that if I evenly wet sand everything I can make it turn out fairly good am I wrong. Am I diving in too deep? Any help from experienced painters would be appreciated. I am looking at paint guns and am willing to spend around 300 what are some things I should be looking for. Also is there a sort of starter kit I can purchase that has all the sanding blocks, papers , tools etc or do I need to pick them up seperately. thanks for any help.
