DIY spray bed liner sanding prep tips
rjrobin2002
What have you used to scuff the current paint in your vehicle before spraying bed liner that went relatively fast? I am thinking some type of sanding attachment for a 4.5" grinder would be good. I have a DA also, but I think the grinder would be faster due to how much air my DA takes to run.
Heus33
The grinder is probably a bad idea...
Whats the current condition of your bed now? If its clean paint some red scotch brite pads and a lot of elbow grease will get it done in about an hour.
KS.76Sport
Wichita, KS.
Depending on the level of removal/scuffing you need. I like a wire wheel, wire cup and/or flapper disks on the grinder. They are all pretty cheap at Harbor Freight.
Monster Mike
I just did mine. I used a plastic cup brush. It has plastic bristles that make quick work out of tub prepping. Al's bedliner sells one. I bought mine at the local diy auto paint store for $40
If you go this route you will want to use it at low speeds. On a selectable speed buffing grinder set it to 1-2. I didn't try using the cup on an air grinder but I'm betting electric is better in this situation. If you use it at high speed you will wear out the bristles prematurley & rip right through the paint & primer.
This tool effectively cuts your prep time way down & can get into the corners & tight spots very well. Goodluck!
motoman
Phoenix, AZ
My bed had surface rust that needed to be removed and left over trunk paint
We used a coarse wire wheel on the grinder
We used a flap disc on the grinder (Don't forget your safety flip flops!!) ;D
Tried using a home style sand blaster (no workie) Well it worked some...but not enough pressure or media
Then we completely degreased the area by scrubbing down with a strong DAWN solution and rinsed well
and then a final wipe with Acetone......
We then applied a Metal Etching Primer (to bond to bare metal)
and then the U-Pol Raptor went on......
and don't forget a little fun during clean up!
Rustytruck
Notice above, the best tool to have is a couple of buddies to help you out. Its a 2 day full time job if you do it yourself or half a day and a good BBQ with some friends. Look up Bear-tex scuffing pads in dark tan medium. These are thin and formable to the surface you want to scuff. wear gloves or you will scuff your fingers to the bone. use it with metal prep at the same time if your fighting surface rust too. I also have Als plastic scuffing brush 4" diameter which I got from 4-wheel parts. It uses the large screw on base like on big body grinders. So be aware of that issue if you want to use it on a small grinder. Harbor freight plastic brushes I found inferior for this type of work. dont forget the knee pads. Dont light the Barbque until the work is finished. Beer you will have to ration accordingly I find gluing the pads to the hands and Knees helps, then hag a beer from a stick just out of reach keeps them motivated and hands moving.
motoman
Phoenix, AZ
Absolutely correct about having a couple of buddies!! Major kudos to Steve, Vince and Tim for all their help.
maddygirl
Rocklin, Ca
How is that U-poll? Thats made by Raptor? Im looking to do the bedliner in the next couple weeks and would love to know how you like it. I have two big dogs so I want something tough. Any opinion on the SEM products or Dominion?
bknbronco
North Metro, MN
Ausome pics. I have 8 quarts and two guns of that raptor-x. Im excited to get it sprayed on the bottom of my tub. I might just have to put it on the inside as well.
Is black a ok choice for the inside or would you go with a lighter color next time around? Maybe a grey or a tan?
BlackCat4
Beevile TX
Quick ? Guys my bed has surface rust and small holes at tailgate corners looks like someone put some kind of old liner on it should i cut out old pan i have new pan from TBP or can i put new pan on top of old one.Also what do yall use to kill rust, how do you pant or sprey liner evenly.
motoman
Phoenix, AZ
I would stay with black in my truck.... I guess it's personal preference and how much you use your truck.....
motoman
Phoenix, AZ
Here's the all the pictures from the two day effort of prepping and applying the Raptor Liner
Bronco
Toyota
I am not a body man but you should either remove all the old liner or if it's still bonding well you can coat over it with prep work...... if the old pan is shot just replace it.....
Technique and help from friends when spraying. Each coat goes on in about 5 minutes..... had vince holding up the hose so i didn't drag it through the liner. I little practice first helps too.......
You can go to U-Pol Raptor liners website here
bax
Old Member
Dont use etching primer with the SEM liner. Epoxy only. SEM will not stick to etching primer.
