Spray gun for DIY bedliner
jboomer
Havelock, NC
Well, after visiting every AA Auto Parts, AutoZone, CarQuest, Lowes, AceHardware and TrueValue in two Counties and three towns I finally made it all the way to a Harbor Freight store. No one at ANY of these places have even heard of a "Schutz" gun. I did buy a UPol gun for the Raptor bedliner kit, however after getting home I discovered that the spray containers that come with the SEM kit don't fit the UPol gun and after visiting WalMart, Lowes and the Dollarstore determined there isn't a bottle/jar/container sold at any of these places to fit this gun. So, I returned it.
Anyway, back to HarborFreight....no one could help me find what I needed. They did have a "texture" gun, however it had a 1.2 gal open-topped hopper on the top and I new this wouldn't do I want to be able to spray my undercarriage in the near future and this gun wouldn't allow it). All the HV/LP guns had 1.8mm and smaller tip so I didn't THINK these would work. The largest tipped gun I could find was a LV/LP gun with a 2.0 mm tip so I bought it.
Is this gun going to be able to spray this SEM kit? The gun's requirements are 3-5.5 CFM @ 20-45 psi. The SEM kit recommends spraying between 45-90 psi, I think I can probably squeak another 10 psi out of this gun if it doesn't blow up in my hands!
I'm nearly done sanding/scuffing my truck and will be cleaning it with MEK tonight and one again in the morning and hopefully spraying tomorrow mid-day.
Does anyone doubt this gun will do the job? I'd like to know now before waisting this $230 kit!
Thanks!
mr incredible
the only problem i could for see , would be the tip size in the gun ,, you might have to dilute the mix a bit , to get it to spray the mixture ,, most guns will handle alot more than is stated , i have the same gun , and i have sprayed at 90 psi with it before ,, latex paint though ,,, but thickness should be close to bed liner ,,, all you really can do is try it ,,, and good luck ,,,
TN1776
I shot the SEM bedliner with a gun similar to this:
http://www.eagleequip.com/page/EE/PROD/BDP/7402
I just adjusted my air pressure until I saw a spray pattern I liked. Schutz guns are also called undercoating guns. Any automotive paint store should have them, but I highly doubt any home depot/lowes type places would.
Good luck!
Pa PITT
Stephenville TEXAS
It's been 7 or 8 years since I was in the paint business but I sold schultz guns ..Seems like at 1st I had 3M guns about 45.00 then I think I went to one imported by ATD just a cheap knock off ...29.00 or so ..No one ever uses one of these thing more than about 3 times so why have the best one ...If I remember correctly a shultz gun has a bout a 1/4 inch nozzle out the front doesn't look any thing like a paint gun...I was thinking you sprayed down at about 15 lbs..If you too high the particales bounce everwhere ...overspray ...
Ask for a undercoating gun at a auto paint store...if the dont know what a shultz gun is ....
fordtrucks4ever
DFW
You can use a cheap siphon sandblasting gun to shoot bedliner. Its basically the same setup as a Shutz gun. Just not able to screw the bedliner cans to gun.
jboomer
jboomer
Havelock, NC
Thanks for the help! However, I've called every paint and body shop (no paint specific stores) within 2 counties and no one sells these. I guess I'm going to go ahead and try this one. I'll mix a cup full or so and see if it'll spray. If it won't, then I'm only out a little bit. I've only got a gallon.
mr incredible recommends "diluting" the mixture...what can I thin it with? There's nothing in the application instructions about doing this.
jboomer
jboomer
Havelock, NC
So, I'm out there wiping everything down with MEK and it's taking the paint off. Where I've primered the new floorpans, it's taken it all the way down to bare metal. Is it supposed to be doing this?
The directions say to primer the bed with an etch primer, then clean and sand and clean again. Do I need to re-prime this thing now?
bushman
Oregon City, OR
MEK is bad stuff for any finish, not to mention the permanent nervous system damage and brain cancer it causes. :) I would just use a tack rag after blowing it all off with air.
jboomer
jboomer
Havelock, NC
The most recent LVLP gun I bought comes with a can. The first gun I bought (UPol) was for the Raptor kit and the only can that would screw onto it was the bottles that came with the kit. That's why I had to return it.
The guy at AdvanceAuto recommended re-priming the truck since the MEK took it down to bare metal in a lot of places. He recommended the Dupli-color PrimerSealer (non-sanding). It doesn't say whether it's epoxy based or not, comparing it to epoxy based paint, it looks like the chemicals in it are the same. He said to spray the bed with this primer, let it dry then spray the SEM bedliner over the top of it. Not to even bother with sanding if I do it soon after it dries (same day).
If any of this sounds wrong, please step in! I'll be checking back as things progress. Once I start the bed liner, I'll be doing the quarter panels first. If it starts to bubble AT ALL, I'm stopping there!
jboomer
jboomer
Havelock, NC
Finished spraying the primer. Not too bad, I just put one coat on it. Hopefully this'll be enough for the bed liner. With one coat, the primer is real thin in some places, however there's good paint under those places, so it should stick OK. I'm kind of concerned about spraying the liner on this stuff though without sanding it. The guy at the auto parts store said it should be OK.
BYUBRONC
Bermuda Dunes, CA
I helped in a truck shop for years, as a side job to pay for toys and help a friend out. We installed SPEEDLINER, we would take a wire wheel to the beds of brand new $30-45,000 trucks. Basically knock almost all of the paint off. Then scrub it down with scotch pads, clean up with thinner, spray on the product. We had very few ever comeback with chips, most were peeled up by dragging something sharp and heavy in it.
jboomer
jboomer
Havelock, NC
Yeah, I'm quickly running out of day light and am a little leary about spraying the bedliner with the temps changing and dew starting to form. I may wait until tomorrow afternoon for my wife to return from work (free labor, lol!). In the meantime, I can scuff the new primer with a red scotch-brite pad and MEK it once more.
Anyone agree this is probably a good idea?
66ALRIDE
Just BIP It!
Dothan, AL
I hope you did not use etch primer because the SEM's will react to it and blister up. You need to use an epoxy primer. You do not thin the SEM's. Also when you mix it, only mix a cup full at a time. I think the pot life is like 20 mins, and it means 20 mins. If you're not sure that you're gun will work just wait until you get one that you need, no need in wasting your time and material when a few more days won't hurt.
jboomer
jboomer
Havelock, NC
Thanks for the reply '66! I don't think it was "self-etching" primer. Actually, the only thing the can says is that it's a "primer sealer". Doesn't claim it's epoxy or "self-etching" or anything else. The SEM can does say to spray "self-etching" primer onto the surface though. However, after reading all of threads that I could on the subject, Bax's experience has led me away from anything that says "self-etching". I don't know exactly what that is, but I don't think I want it under my bedliner!
As far as waiting for a gun, well, that's definitely a problem. I just used up over half of my "post-deployment" combat leave prepping, gun hunting and researching this stuff and am out of time. I should have had it finished today, but spent all day taping and then spraying the new primer (since the MEK ate all of the orginial primer off!). However, my plan is to only mix 1 cup of the bedliner at first and try and spray it. If it won't spray then the next chance I'll get at spraying will probably (hopefully) be thanksgiving weekend. If it will spray, then I can get it done tomorrow and be through with it!
Thanks again for the reply though!
fordtrucks4ever
DFW
No different than lacquer thinner and acetone. Of course its only known to cause cancer in California.
jboomer
jboomer
Havelock, NC
Yeah, after speaking with texashcane, I may have been using that stuff improperly. I was pouring it onto a sponge and then wiping the surface down. I take it the proper way to use it is to "dampen" a cloth and then wipe the surface. Oh well, I got a new coat of primer out of it!
