Steve83
Mahle bought FelPro. FelPro was the OEM for Ford gaskets, so now Mahle can call itself the OEM. But AFAIK, Mahle gaskets are cut from the same dies as FelPros.
Threadlocker is also an effective thread sealer & anti-seize, and I use it on the IM bolt heads, to seal them to the IM. But there are NO bolts on the engine that are supposed to be in coolant. If everything else is sealed as-designed, you can drill weep holes into the 4 IM corner bolt journals, and nothing will come out until a gasket fails. Same for the 4 long bolts that pass through the WP & TC journals into the block. I usually don't even seal those journals so that they CAN weep.
(click this text)
On TC gaskets, I only put extra sealant around the coolant journals - I specifically avoid the long bolt journals so that, if coolant ever get into them, it can get out even easier.
(click this text)
(click this text)
![](https://www.supermotors.net/getfile/624439/thumbnail/50lexploded.jpg)
(click this text)
![](https://www.supermotors.net/getfile/1168690/thumbnail/timingcvrgskt58l.jpg)
