Do you need twin stick mod when changing to ZF trans?
Preston
I just purchased a Cummins 4bta to put in my bronco and I am going to use a ZF trans. I have the J style transfer case shifter and I am wondering if I need to replace the J shifter with twin sticks?
Thanks,
Preston
Amac70
ME
What ever you do you will have to fab up something for the zf. no stock set up or twin stick will work with out modification.
P
Preston
What did you do for a transfer case shifter?
How do you like your ZF?
Did you have a body lift? Is a body lift mandatory?
Thanks,
Preston
Amac70
ME
I made my own twinstick set up. as for the zf I like it, its a nice driveing tranny, good for trails and the highway. Body lift will make it easier and fit a little better. When i first did mine i did it with out a body lift and it fit fine. But after installing it i could not get my long tube headers in. I believe if i had put the headers in before installing the tranny they would have fit fine. If your running the 4bt you wont have that header problem.
bronko69er
EB Addict
Renton, WA
I used my stock shifter (T-shift though) with a few minor bracket mods to the BC kit. 1.5" Bodylift probably want at least 1"
Love the ZF BTW.
bronko69er
EB Addict
Renton, WA
[Hyjack] Amac, does your ZF sound like it has gravel in it too (below 1000 rpm or idling in neutral)? I've heard its normal but I'm starting to be annoyed by it. [/Hyjack]
Amac70
ME
yeah thats a good analogy gravel in there. Its loud its annoying sometimes more then others. I actually yanked it right after i bought it cause i thought it was bad and had it rebuilt. Sounded exactly the same when i got it back. Im going to get some thick rubber floor mats hopefully that will reduce the noise a little. Even after 5 years the sound bugs me but it still trucks along just fine.
P
Preston
Thanks guys.
I was going to get that BC Broncos kit to install the trans, but its pretty pricey. What did you guys do for cross member etc?
bronko69er
EB Addict
Renton, WA
I did the whole BC kit, at the time I had very limited access to a shop so I had to bolt in as much as I could.
I actually shopped around for all the part to compare (back in Sep 2004), and you wont pay much more to just buy the kit. The small difference in price wasn't worth my time to try to piece meal the hole package form different sources. I'm sure you could make your own cross member and shifter bracketry, but thats about it. If I were to do it over, I would have gone with a NP205 to avoid the expense of an adapter. I still might down the road.
Amac70
ME
There were no kits when i did mine i built everything myself. My crossmember is similar to what bc sells now except it is two tubes with plate inbetween them with a bushing mt in the middle again similar to bc's.
trtlsoup22
I built my cross member out of channel iron. I will have to post some pics of it. It took me about an hour to build it. All you need is a chop saw and a welding machine. I took some angle iron an secured it to the original bolt holes from the stock member.. then I used some tractor cab rubber bushings to go between the angle iron and the cross member.. works perfect "poor people got poor ways" The ZF is noisy, but it is well worth it.
P
Preston
What did you guys use for clutch? Stock ford or something after market?
Advanced adapters sell the adapter.
http://72.20.96.178/commerce/ccpc1022-1113-ford-zf-adapter-kit-50-4303-50-4303.htm
BC broncos sells a whole kit that includes crossmember, master and slave cylinders, hydraulic line, etc.
http://bcbroncos.com/store/product_info.php?cPath=24_62&products_id=347
Hey while I was getting that link I noticed it comes with a transfer case shifter mount. So maybe I don't have any fabrication to do. My skill are limited to impatiently bolting stuff together.
Preston
trailpsycho
Preston
Then how do you plan on pulling off the 4bt swap? That is pretty fabrication intensive...frame rail/crossmember mods and/or custom engine mounts just to get started....? It all looks great on paper, but there is alot of custom work that goes into every Brocno drivetrain swap.... there are very few things that are bolt in swaps...especially if you want to change out the motor. Something at some point will require custom-fab. Going diesel is adding a huge level of complexity to the swap. I hope you are up to it. IF not you will learn alot. Best of luck.
JB Fab
I never noticed it in my company trucks 500K miles, but as soon as I put one in the Bronco (with no tunnel cover yet), I got a little pissed-off thinking I got screwed on the tranny. I jumped under a couple of company trucks while they were running, and they are noisy, I guess the carpet / mat / tunnel cover make the difference.
Jon
bigmuddy
Marthasville Missouri
I run the ZF as well and it's a little noisy, sometimes more than others. I have been told that ford added some foam over the tranny in addition to the carpet and mats to keep the noise down. Mine does not make noise in first however, only when idling. I also used the twin stick from JB fab and it was a super easy mod but the way I installed mine it moved the shifter back toward the console between the seats but still a good location. By the way, the JB Fab shifter is really built well and is cheaper than the others, oh and it comes with a super rubber boot as compared to the others.
As others said I would buy the BC kit, I didn't buy it all and peiced most of it together around town and I don't think I saved much money if any at all.
I do have a homebuilt crossmember for the ZF that I didn't end up using that I would like to sell.
Ben
agent_orange_71
Bluefield, WV
Sorry to highjack, but who sells an adapter to mount the zf the 4bt motor?
The cummins engines have a mid plate that goes between the block and bellhousing. There are a BUNCH of different ones around now that the swaps have gotten popular. The ford small block pattern ones are actually available new from cummins. PN--3908022
P
Preston
Trailpsyco, my brother in law is a welder and has some pretty good fabrication skills, so I will be leaning on him heavily. Also the BC Broncos kit has a crossmember, don't know if it has to be welded or bolted on (Chuck is apparently at Baja, so I can't get any questions answered). My wife is more enthusiastic about this than I am, so it looks like I married into the right family.
Soclair, sorry I answered the wrong question. If the 4bt came in a ford it has a ford small block adapter plate bolted to the block. If it came in a GM product the adapter is for GM products, usually it seems like the GM stuff came with a TH400. Also if you want to spend some bucks PATC has some adapters, flywheels and starter kits. I think they are on ebay for $1300-$1400.
http://www.transmissioncenter.org/cummins_4bt_and_6bt_adapter.htm
Sorry for the confusion
