Dodge wheels
doghows72
I have a question for you guys. I found a set of 17" dodge steel wheels. The info I am getting from the guy is they are 17x7 and have the correct 5x5.5 lugs. My question is about the backspace and the center hole. He said the backspace is about 4-5" and the center hole is three inches in diameter. The backspace I can work with as my truck will be uncut one inch body and 2 inch lift. Plan on running a 33x10.5 tire. The center hole is my concern I know they need to be enlarged.
Do these sound like they will work?? Thanks Steve.
broncobsession
1sicbronconut did it. PM him. There are pics somewhere in the LUBER thread that Shamu started.
I have heard of them working. Proper thing to do is find a machinist who has a big enough lathe to chuck up the rims to properly bore out the center hole.
Not sure about the backspacing.
broncnaz
bad part about the increased back spacing is the tires will/may rub the radius arms on turns
doghows72
doghows72
Thanks guys. I have a friend that can handle the center part. Needs to be opened up 1/2 inch total, so only 1/4 off each side so to speak. The backspace is 4 -4.5 inches so I might need a small spacer which is fine as this will be a mostly street LUBR.
Appreciate all the help.
MyOriginal66
Once you open up the center bore they will fit perfect. If you run BFG KM2's in 255/85/17 (33x10x17) they shouldn't rub. Of course every bronco is different.
