Mike Hewett
- Mar 1, 2004
- 358
Here is my dilema, sort of.... I put 35" x-terrains on my bronco and haven't changed the gearing form stock. I am putting in an np435 and I was thinking that the lower first gear would actually be lower than the 3speed even after the bigger tires. I mean the 1st gear in the 435 is twice as low as the 3speed and the tires obviously aren't twice as big. I was then thinking that the bigger tires would have an overdrive effect on the bronco. I won't be doing any serious off-roading so for right now I will live with these gears until I can afford the swap/axle upgrade. Do you guys agree with me on this or am I way off??? Does anyone run this combination.
