Does the transfer case have a vent?
boatbldr
Fort Collins, CO
I plan to do some fairly deep water crossings this weekend, I have vent extensions on the diffs, but don't know if the transfer case has a vent I can raise up to keep water out. Any ideas?
rflud
Modesto, CA
yep. You just need to pull off the cap to be able to put a fitting in for a hose. Oh, it's on top of the rear output shaft housing.
70_Steve
Old Guy
Yeah, remove the vent, just above the output shaft yoke. It doen't unscrew, so just pry and twist... Leave a hole that's just the right size for a 1/4" NPT tap. I just did this on my t-case, but mine's on the workbench being rebuilt. Not sure if you'd want to have all that iron going down inside the t-case. If you've got a new gasket, pull the rear OP shaft housing off, tap the vent hole, then reinstal the housing...
rflud
Modesto, CA
JB weld works wonders. Just put a weatherhead fitting there and slap some JB on it. Just make sure you get all around the fitting and it will be water tight.
BwoncoHowie
C-4 Wizard
The transmission vents separately from the TC, I hope you got that covered too.
