Doing Rear Wedge Shim Install, Need Torques
Mikey
Read the excellent Tech Article on installing the rear wedge shims to correct the pinion angle. It doens't give the torque values for the u-bolts or the leaf spring tie bolt.....suggestions?
Thanks,
Mikey
70_Steve
Old Guy
Thanks,
Mikey
Suggestion - Google "U-bolt torque"
All depends on the size (diameter) u-bolt. I used this table: http://www.autoandtrucksprings.com/pages/U-Bolt_Torque.html
That might have been my tech article. Thanks!
M
Mikey
Same for the spring tie bolt? Just use the same chart? Thanks!!!!!!!
Gweiner
Charlotte
Where is that tech article on rear wedge shim install? Did a search and can't find it. Appreciate any help.
doran4x
Re-torque u bolts after driving first time. Check torque after a couple of hundred miles. Check torque before any off road trip.
