DOM tubing
NC-Fordguy
Bethel/Greenville NC
Guys
I was wondering what 1.75" .120 wall Dom tubing is running in your parts of the country?
$3.50 a foot here in eastern NC
IIRC it was running $2.50 a foot a couple years ago
JDJ
Dothan
I priced some a few weeks ago
1-3/4" .120" was $4.35/ft
I'm in Dothan, AL but I priced it from a place in Chatanooga TN
bax
Old Member
Right at $ 5.00 a foot here DOM 1 3/4'' .120
BroncoWanted
North Mississippi
You guys can actually find it without have to have it shipped????? I found it on the internet at a place in Saint Louis for 4.60 a foot plus shipping. Cheapest I could find it for me without buying 100 feet.
Greg_B
Cohutta, GA
I know it has been discussed before but I still have a hard time believing DOM is required to build a safe cage. I was touring a tube mill a couple of weeks ago where we buy about a million dollars worth of tubing a year. I asked the plant manager about the difference in strength between the two and he laughed at the idea that there was enough difference to even care. In his opinion the only real reason for DOM was for the exact tolorance on the ID and OD of the tube. I asked why does NASCAR use it if it isnt stronger and he said because of liability issues. They didnt want people using crappy quality tubing that might not be welded properly or out of round. His opinion was that properly welded and true round welded tube was just as strong if not stronger than DOM since some material is lost as it is drawn over the mandrel.
Dont change because of my opinion I just thought I would share what the tube mill told me.
Greg
needabronco
Prescott/Farmington
I paid $2.25 per foot a couple of months ago. this was at a steel shop in AZ, the shop here in NM has a minimum purchase of $40. Shipping kills any deal so buy locally. Also if you only need a short length ask if you can sort through the scrap pile, that stuff is usually deeply discounted to free.
BlackHills4X4
Rapid City, SD
I just purchased 120' of 1 3/4 .109 tubing for $25.00 per 20' here is SD. We use this tubing in all of the stock cars (late models, sprints, etc.) out here. They fall into compliance with the WISSOTA specs. I have never seen any failures due to the tubing. Welds and cage configurations...well that's another story. They should inspect those too.
Nightstick
Bronco guy
I'm with Greg on this one... 1 3/4" .120 is $0.69/ft where I shop. I think as long as your welding skills are good a non-DOM cage would hold up.
Nightstick
Bronco guy
Lol, yes it is but I'm talking just regular old round pipe not DOM as far as I know. I think as long as you'd have more than just a four point cage but rather one with multiple bracing and frame contact points it wouldn't fail. I might go with a .170 wall instead of .120 but still much cheaper. I know guys that weld for a living and have worked with metal for many years and they've never seen a seem failure... I'm no engineer though so what I'm saying is just what I believe not proven by science.
J and I Manufacturing in Madill, OK is where that price comes from by the way, and all their prices are listed online.
Durtymax
$2.50 per foot here in Medford Or. The other big difference with DOM and HREW is the seam can crack and let moisture in. Water will build up and cause all kinds of problems.
ned72
Truckee
i went to Wyotech for school and was taught that dom is best but as long as it is properly fitted, welded, braced and there are no sanctioned rules dom is not necessary.
