What worked for me was snugging the hinge bolts, use a small block of wood and a hammer and adjust the hinges however you need to. You want the bolts tight but not to tight you cant move them easily with the hammer and wood. To get the bottom front to come out where I needed it, I actually got inside and grabbed the top of door and gently bumped it at the bottom at the front corner to get it to move out. Nothing I did caused any type of damage to the metal or hinges. Just take it slow,stand back and look at what needs to shift to make it right. Mine ended up being damn near perfect.
