I've had good luck with tight enough to hold it from moving but loose enough where you can adjust it with a little force. Get it just right and then cinch those suckers down!
Take the striker off and get the doors aligned in the opening first, then align the striker to where the door will close. Don't try to do it all at once.
Thanks for the advice, I think I will try the tight enough to be moved with a little force and without the striker post installed. I'll let you know how it goes.
I will be adjusting mine soon as well. I got a set of the wild child lift off hinges for my "Cut out all the rust and put a fresh coat of paint on the Bronco" project. I recall that Bronco Driver had an article on adjusting doors some time ago. I'm not sure what issue it was but I plan to dig through my back issue before I try to replace my hinges.
