Here's what I have done to get at least my driver's side door to work.<br>1) rebuild the hinge. It's not that tough and alot of the problems start with having a worn-out hinge<br>2) get some type of jack to prop up the door so that when you loosen the bolts, the door doesn't immediately drop down. The door is very heavy and a pain in the !#s to take off (and to put back on as well).<br>3) after you rebuild the hinge (there are kits available and links in the web section on how to do it) also cut some sheet metal (roughly 1/16 to 1/8 thinkness - I don't know what gauge this would be...) the same size of the hinge face and drill holes to match the bolt holes in the hinge. These will be the shims for the hinges. I cut about 4-5 of these for use on my doors. I used thin sheet metal so that I could fine tune the fit better.<br>4) when you re-install the hinge, depending on where the door is hitting the frame (or just sagging in your case), place a shim, bolt everything up and see how it works. You will probably have to play with this a bit but once you get it dialed in, the results are great.<br><br>My driver's side door works great now... I just some time to fix the passenger side now. E-mail off line if you have any other questions.<br><br>Jon
