Door hinge post replacement. Mad's easy way
Madgyver
Bronco Madman
This has been my quickest and easiest replacement of a door hinge post. I've done 3.
I'll share what we did.
I found a good candidate for a replacement off another tub that was cut up. It was in better than the hinge post that was on the firebronco so I cut it out.
Built a jig and bolted it to the floor on the front cage holes and welded it to the windshield mount and then connected and welded it to the existing door hinges to locate the hinges in their original spots.
The rest was simple... Follow along.
Madgyver
Madgyver
Bronco Madman
Bolt in replacement, check fitment and weld in place, remove jig, finish welds and install door.
71 CA Bronco
That is slick. Great idea. I wish I would have known this trick when I did mine. By far the hardest thing I did on my frame off. Bravo!
