Jeep Slayer
Just got done with putting new pins in all my door hinges. If you plan on under taking this MAKE SURE to have the use of a large press as I tryed a small hand press and was unable to pop the pins.So I was forced to use a large hydraulic press. Tip # 1 Don't try to pound them out with a hammer it won't work and you will just damage the pin . you can drill them out but if you do make sure you hit the holes stright. you should be able to press the new pins in with a small hand press. This made a great diffrance in the play in the hinges have not reinstalled them as I kind of like it with out doors it will have to waite till it get a little cooler I got my rebild kit from JBG. just thought I would pass on the info<br>
