Door hinge recommendations
Bitch'nBronco
Loose Cannon
Ringwood, NJ
My wildchild lift off hinges are about cooked. I don't really care about taking the doors off anymore and want to go with stock style hinges. Any recommendations? Was thinking about repinning a stock set but have heard they don't work all that great and I have a good chance of misaligning the holes
Sent from my SM-G981V using Tapatalk
I would go with a stock ford set at least they were once drilled in the same drill jig.
BroncoJimbo
Long-term owner
North GA
I am need of new hinges as well. Where does one get new stock Ford hinges?
I've heard the Duff's hinges are quality but they are pricey.
I could be wrong but I think Rustytruck was just referring to a stock replacement set. Not necessarily OE Ford stuff.
Although that's usually considered the best route!
In the case of the hinges though, as I can attest since I still have a set of brand-new-from-Ford hinges, the modern aftermarket hinges are actually better. At least in the tight action department.
The stock original OE replacements I got from the dealer in about '79 or '80 or so (could have been later, but not sure anymore) are loose and sloppy as the ones that were on my '71. Hence my still having them in the garage still with the part decal and a label with my name on it wired to a hole.
They're super sloppy...
When I took a set of our new replacements (https://www.wildhorses4x4.com/category/s?keyword=door+hinge) out of the box a couple of years ago I was very pleasantly surprised. Not sure who makes them, but they're a very fine piece of work.
Again, not sure if that's what Rustytruck meant, but if it was there is good reason for it.
BroncoJimbo
Long-term owner
North GA
Thanks Paul. I added a set of four to my wish list. I just need to schedule the time to get er done!
one thing to keep in mind the stock ford hinges are not all the same. if you ever had several sets of door hinges in you hand and look at the inside of the hinges on some of them you will see additional press marks to adjust the hinges. they pressed the hinge to adjust door gaps on problematic door openings and reluctant door gaps. moving the door left and right in the door openings.
Jakedog
My dad and I re-pinned the ones on my 75 back in the 90's and they came out great.
I would try the re-pin.
I have always repined the old ones but you have to be careful when re-drilling them as they are made line a precision piece going in. always mark them from the location you took them from and put them in the same place.
