Door Insert Help
71 BRNCO
I just picked up a set of the fiberglass door inserts which i think are from an older Kentrol body. They are in really good shape but I have several questions that I could use help with. They came with no hardware or no holes drilled and I need to figure out how to mount them. Can anyone post detailed pics of where they have there inserts screwed in or any creative idea of how to mount them without having screwholes on the outside? Either way I just need some pictures to work off of to figure out how they should be mounted. Secondly they seem to have a slight bit of gap around the door is this normal? Hopefully if somone posts pictures of the screws then I can compare. Should I have my door weatherstipping installed with the inserts? These came with fiberglass inside panels-Any idea of how to mount these or does anyone here have these inserts that can help or post pictures.
Lastly, the bottom seems awfully weak and I am affraid they will crack easily did anyone mount anything to fill the space between the doorsills and the bottom of the inserts?
Please up close pictures of the outside and inside from several people would really help me. Thanks in advance! kyle
Slick
Petoskey, MI
I'd sugjest triming them 1st...
they are not made to be installed with the weather stripping on, UNLESS you trim out some of the insert 1st!
after that it's simply a matter of find'n where the body meet's up with the inserts, like I'd do a total of 12 holes... 4 per side.
However, if yer never going to use the full doors then just take out the weather stripping and forget about it!
:cool:
71 BRNCO
Please someone post a few pictures to help me out some closeups or ideas. Anyone?!?
j.r.nice
I have a set of the old Kentrol/k bar s inserts that didnt use external screws. They were a real PITA but I havent gotten around to 'glassing them in yet.
Anyway, they came with about 12-14 (6-7 per side) "L" shaped aluminum brackets about 1 1/4" wide and about 1 3/4" per leg.
these have to be mounted in the jamb and on the inside of the insert. I suppose some owners used screws on both sides but I glassed in the insert side and screwed the jamb side so I could take them off in the winter. I didnt have any exposed screws but it was a lot of work and requires funny hand bending when installing and removing.
I used thin welting/ piping/ insulation that I got at the hardware store. I used this to keep junk from coming in from around the insert. I mounted it with small pop rivots. The fit on my inserts was crappy because one side was too high etc.
I prepped my angles by drilling 1/4" holes near the end of each angle. One end will have a screw going thru it and the other will allow whatever bonding material you use to hold better. I used really good 2 part epoxy glue but in hindsight I would have used it just to "tack" the angle in place and then have it glassed in. There's a lot of vibration and I had to re-glue some of mine at the end of every summer.
To mount mine (there probably are easier ways), I used duct tape (or have someone help) to hold the insert where it looks good. Put one of the angles against the inside of the insert and the jamb. I marked mine with a permanent marker. Mark both holes - 1 on the jamb and 1 on the insert. Drill the hole where the screw goes in the jamb and use either gripserts and 1/4 x 20 screws or use large sheetmetal screws. (like size 10). If you want to double check it (after you get the angles screwed to the jamb) refit the insert and mark where the hole in the angle hits it and trace around the outside of the angle to make sure it ends up the same as when dry fitted. .. You can either pull them off and glue them or glue them on the truck. Then after they dry, unscrew them from the jamb and glass them in well.
The other styles of inserts used an aluminum or sheetmetal filler - but I have never seen one installed......maybe someone else will help there. I would be interested hearing about using those.
I donthave any pics - sorry
HTH
J. R.
71 BRNCO
My apologizes Slick. I didn't mean it like that. Thanks for responding to my post. I am having trouble deciding where to drill the holes from the outside. Do you know of anyway to mount these without have many screws on the outside???
jims66
here is one
jims66
five, let me know if you want more
todcolvin
Jim--
Those are great pics. I had the same question. They will help me next week.
Do you have any of the fillers on the backside?
Thanks, Tod
jims66
#3 Let me know if you need more!
todcolvin
Now it makes more sense. Thanks!
Jim--That roadster is very impressive. I am continuosly amazed at the detail work you have done.
Thanks, Tod
71 BRNCO
Thanks Jim. That helped alot. I think that is how Slick told me to mount them i just couldn't visualize it done. I do wish I didn't need to drill holes but it looks really good. I love your roadster by the way
74bajabronco
Berlin
Door Inserts
Thanks for the photos. I'm dealing with this issue right now.
I was looking for a clean way to mount them, not sure what to do
at this point. Craig.
