Door post replacement
Wyo4x4er
Ok so I have replaced my kick panels, inner rocker and rockers and floors and rear door post on both sides. My question is what do i use as a measurement for my door post height?
I have my kick panels in the same height as one another and my drivers door is looking good with about 7/16" gap along the entire bottom. My passenger side is another story. It has a gap about 9/16". This measurement is with hinges all the way down on the door post. I have the drivers all the way up to the kick panel but the passengers is about 3/8" below the kick panel.
SO how many of you had to move the door post down like this? Any tips to check before i cut it back out and move?
kip60
These should help. I have seen people post that you need to put your fenders back in their original position to help locate the post as well. I'm sure you can search the site a little deeper and get more details. Good luck. I am in the process as well. Doing floors right now.
JAFO
Beaverdam
I did both door posts. First, I used self tapping sheet metal screws to secure it until totally sure it was ready to weld. Most of my Bronco was held together with screws and vice grips for a long time.
Anyway, as the other poster mentioned, you need fit the fender and door. Temporarily mount the post with screws. You are using new body mounts I hope. Doing this with the body on the frame? I need to look at your garage if you have one created.
Measurements are great for getting you in the ballpark, but then it seems fitting all the pieces of the puzzle together is what it takes. Look at how the post meets the sides of the cowl.
See the pic below...see where the very top corner of the fender lines up with the side of the cowl? In doing mine I found this location pretty critical for aligning stuff as you want the fender, door post and all in correct alignment so that where the fender out front meets the hood is nice and even. And then once I had the door post welded in, I remember having to sort of pound the outer flange on the post forward some so I could get the fender just where I wanted it. Do tons of fine fitting well before you take it to paint. You can't easily fix once painted.
And if you dash is out, fit that back into place as well. Make sure all the holes are lining up correctly.
I am trying to find a picture showing things better. This is what I started with. I have the body hanging from an I-beam above using threaded rod, so I could adjust things to get the posts back in. It was a nightmare really.
The Bronco kind of evolved. I did sections at a time. Later the whole cowl was replaced as when I finally removed the dash (after I got the door posts in and felt all was aligned) and found tons of rust in the cowl, so cut that out and replaced. But by then with the posts where they needed to be I had known good pieces to work from. Basically you try to keep sections of known good aligned parts so you have something to work from as you move on. That is how I did it.
It isn't perfect, but plenty good enough for me.
rydog1130
im basically in the same boat as jAFO was and he's right. the measurements put you in the ballpark but it takes some fiddleing to get them right
AZ73
I did similar. Got the post close to factory figures and used a few self threading machine screws and vice grips to hold it in place. then I hung the door and fender and adjusted the door as best I could. Then undid the post, moved it about 1/8 and re screwed and clamped. It was perfect. Pulled the screws and welded. welded up the old screw holes on the kick panel, then used a HF spot weld drill to drill a bunch more holes and welded them up.
http://classicbroncos.com/forums/showpost.php?p=2286267&postcount=68
http://classicbroncos.com/forums/showpost.php?p=2303666&postcount=71
Reggie007
Orlando
For the one diagram with the drivers side measurements, does anyone know what is point "A"? I can't tell if it is the lower corner or the upper corner? Is it on the window frame, or door post?
JAFO
Beaverdam
Thanks. Was so much work, but in the end worth every bit of it. I started building my cage today. Will post some pics.
rydog1130
Correct me if wrong but on mine Point A is the center of hinge pin.
I used the corner below and behind the hinge pin as my reference, it doesn't make much difference. These measurements get you close but it just comes down to eyeballing it and moving it until you get your gaps right. Sheet screws and clamps are your best friends!
JohnJohn
Richmond
When I did my door posts I tack welded the post to the kick panel vs. screws. I had to move the pillar 1/16" of an inch several times to get it perfect. If I had used screws my panels would be turned into swish cheese.
