- May 24, 2004
- 3,413
My driver's door has never closed right and I've got a new latch to put on it. It has always had weird symptoms like it won't unlatch to open once you try to open it with the lock in the down positition. Even after you pull the door lock back up, it won't open and you have to take the panel off the inside (not fun with seats in it and closed) and do it manually. I've got a nut on the door lock to prevent me from even pushing it down - no big deal it doesn't have a top anyway.
Now the door wont close all the way. It catches as if you didn't close it hard enough, but unless you really slam it then it won't close fully. I noticed that the striker has a collar on it and it is loose. The passenger side is not loose. I tried to pinch it tight again, but that didn't work. Can the collar be removed, or do I need to replace the striker with a new one?
Thank you!
Thank you!
