Door Window Frame Chrome Molding Install Question
tbratz
I am finally getting around to installing the chrome molding that goes around the door window frames and was wondering on how they go on. Do they simply just snap over the frame, any tips would be appreciated.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I've never installed a set but have removed a few. They just snap onto the frames using spring tension. They're removed by gently prying with a putty knife, being careful to move around and not using too much torque so they don't get bent. I would imagine they're easier to install than remove. Make sure you install them in the correct order as the pieces overlap at the corners.
