Double cardan seal
bfluegel
What seal do I put around the ball stud in the double Cardan joint?
I bought the JBG driveshaft repair kit, but it didn't come with any. My old seal was mangled beyond recognition, except that there appeared to be both rubber and metal parts in the mess. I found a Spicer catalog (www2.dana.com/pdf/J300-P5.pdf) that showed either a slinger or a seal, so I bought both. I thought one or the other should be pressed onto the lip of the yoke, but when I tried, their inner diameters are too large. The O.D. of the lip is about 1.499" and I.D. of the slinger is 1.509. The seal is even bigger. The lip doesn't appear to be damaged.
turbotim2
____________
B
bfluegel
How does the ball and bearings look in the CV head? You can get this Kit: http://broncograveyard.com/bronco/i-12458-cv-head-ball-and-spring-dana-spicer.html and reuse the old bearings or just get a new CV head like this: http://broncograveyard.com/bronco/c-32-drive-shafts.html and be done with it. I tried to go with the new seal but changed my mind afterwards because I didn't like the condition of the bearings.
The seal/slinger that I'm thinking of is something different. The one in your JBG links is assembled in the CV head. It holds the ball into the head, right?
I'm looking for a seal which is attached around the stud in my photo, so that it seals against the outside part of the ball when the CV head is placed on the stud. Maybe I'm confused because there were only fragments there when I disassembled my old one. But in this site:
www.mallcrawlin.com/forum/showthread.php?7478-Double-Cardan-Rebuild
a similar joint is disassembled, and you can see photos of an old seal removed from the stud. He then replaces it with a "splash ring" which is pressed on. My slinger looks like that, but it's too big to press on.
turbotim2
____________
OK, I see what you are talking about in the mallcrawlin thread. I don't recall mine having that seal when I rebuilt it so I wasn't sure what you were talking about.
