macascio
I have taken my rig to get it aligned twice to be called both times to come get it. The first time on the rack the driverside tire when shaken moved and showed some motion or slop which looked to be bad tie rod or dragline. I replaced the draglink, tie rod looks to be good, still same looseness when tire is in air on rack and shaken. Everything else looks tight, i did put a disc conversion kit on but used same orginal knuckles. on passenger side tierod has what looks to be a rubber bushing around tirerod treads that makes it tight when nut is tightened, on drivers side new link has a internal grease fittin that puffs up when greased and then the nut, should there be a rubber bushin on this side as well, could that be the missing piece that makes it all loose, any help here guys would be great, and oh its been a long day so please no wiseguy questions that are intended to make me look dumb, as always thanks for your help! mac
