Drake Headers wheel well clearance
ngsd
I bought the Drake header and Duff 2 into 1 system and got it installed. They sound good but go right up against the wheel well on the passenger side and started burning off the raptor liner as soon as it heated up. Anyone else have this issue with these and what are your solutions other than bend or cut the wheel well? I was thinking about putting some Bilt Cool plates there but not sure how much I could clear it.
spap
Does it hit both sides, maybe you can move the motor over slightly but loosening the motor mounts and d
Shift the motor over and carefully bend the inner panel out a little
That sucks
ngsd
ngsd
No the other side is fine. The pass side is fine too except the two rear tubes are so much further out than the front two.
Several brands get really close to, and often touch that part of the passenger wheel well.
Adding liner to it just made it more of an issue I'm sure. Especially now that there is a meltable substance in contact rather than painted metal (which will still burn, but likely lasts a little longer).
The most common "cure" is to trim that portion of the metal. Some have tweaked the headers, and that is doable from the business end, but that means pulling the tubing off of the collector flange. Some would rather do it one way, others like the other method.
Twisting the engine in the V-notch of the mounting towers is an option for some things, but not sure how it would work here and don't remember anyone doing it recently. I did it with a friend's with BC headers that hit either there, or at the frame (I don't remember) and it worked like a charm.
Seems like a heat shield of some kind would be a quick fix, but it's still physically touching for now, so ultimately you want to create clearance I would think.
Also check your ignition timing to make sure that your exhaust is not running hotter than it needs to. More ignition advance "usually" makes the initial exhaust temps lower in the tubing.
Good luck.
Crush
Greenbottom, WV
Reach in from the fender opening by the tire. Stick your fingers in by the header where it touches. Grasp the edge of the inner fender and pull towards yourself. You shoukd be ablle to bend it enough to clear
ngsd
ngsd
I tried that, there is no give in it.
1970 Palmer
It looks like a really nice rig.
I doubt your going to be happy with any quick fix solution. Pull the right side header back off, cut out the #3 and #4 tubes, shorten them to match the #1 and #2 tubes and TIG it back together. It sucks that it would need to be recoated.
Sorry, just the way I see it.
John Palmer
Rustytruck
Maybe loosen the body mounts and push the front of the tub over? probable causes more problems than it fixes.
Actually that's a great idea. Can't think of any insurmountable problems. If the steering shaft has been upgraded already, there should not be any angular issues (and the amount of movement you can get shoving on the body is not that great anyway). Maybe need to trim some sheet metal around any shifters through the floor, but then again maybe not.
Can't think of anything else off the top of my head that would be greatly effected.
ngsd
ngsd
I did get a little out of the body mount movement but now I am seeing gap issues in the door alignment! Fix one break another!. I was able to get behind the shock tower and bend it a little without it looking bad. It gave me about an 1/8 inch so at least it is not touching.
