Drip Rail repair
ClintEastwood
London, Ontario Can
Hey guys
Curious if anyone has ever had to replace the entire drip rail on a halfcab or full top? My entire drip rail was removed by the P/O due to rust. The rest of the halfcab is almost perfect and I'm hoping to make it work somehow.
Thanks as always
bronconut73
Check with JBG. They sell parts of the hard top in pieces. Maybe they sell drip rail too.
If not it looks like the full size Ford vans were still using that drip rail into the 90's and you may find one in a junk yard you could snatch.
Then it is just a matter of carefully welding it in.
TwoDalesDad
When I rebuilt my Half Cab Top I used some stock I found at the local steel supply. I may be biased but ....It came out better than new... I should have taken before/after shots...cause no one would believe just how awesome it is...
ClintEastwood
ClintEastwood
London, Ontario Can
thanks for the advice. I have a full top converted into a halfcab i'm eyeing. It's bigger than the regular halfcab and I think i can steal the drip rail off it and cut it down to size and weld it on
Pa PITT
Stephenville TEXAS
. 2Dales DADS .. SHOOT us a picture of the finished product. Now I'll say that when I HAD MY PARTS STORE back in the 80's era . I sold a lot of drip rail sealer . 3M 086-- #... AFTER THE RAIL WAS IN PLACE you just put some sealer in on top & smoothed it into place.
ClintEastwood
ClintEastwood
London, Ontario Can
This is an interesting product. Its the drip rail but in a plastic basically then it seems?
Vs the stock steel...do you see a difference in using the plastic? I suppose rust would no longer be an issue...any opinions?
