The sealer in my 77 drip rail is hard, cracked and needs some repair. What did Ford use to fill and seal it. I am thinkng seam sealer but it will take a lot of it.
Ford used regular old seam sealer in there originally. That stuff shrinks and is the reason most all of the hardtops rust out on the inside rail. The outside drip rail runs through to the inside. So rain in the drip rail will run through and sit in the inside channel and rust the top out there. There’s a total of three pieces sandwiched together there for rust to get in. When I rebuilt my top I had to remove the side panels and replace metal under there. Once everything was welded back together, I scraped out all the leftover old seam sealer then sand blasted the drip rail channel. Sprayed two or three coats of 2k epoxy primer. I then filled the drip rail channel up all around with 3m flowable 2k seam sealer. I believe I used three or four tubes of it to do the full hardtop.
I forgot to
Mention this. That 3m 2k seam sealer takes a special gun. They aren’t cheap. I made my own out of two el cheapo caulk guns. It’s not pretty but it got the job done with no issues.
